telnetd - printk for sparc/leon
    Jerry Needell
    jerry.needell at unh.edu
    Fri Dec 12 12:00:59 UTC 2003
On Dec 11, 2003, at 2:57 PM, Fernando RUIZ CASAS wrote:
> On Thu, 11 Dec 2003 10:15:17 -0500, Jerry Needell wrote:
>> I am trying to use the telnetd daemon with the sparc/leon1 bsp
>> (4.6.0pre5) but get the following error:
>> [needell at needell telnet]$ make
>> sparc-rtems-gcc --pipe
>> -B/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/ -specs
>> bsp_specs -qrtems   -g -Wall  -O4 -g       -mcpu=cypress -msoft-float
>>     -c   -o o-optimize/init.o init.c
>> In file included from init.c:49:
>> ../networkconfig.h:70: warning: initialization from incompatible
>> pointer type
>>         -o o-optimize/telnet.exe  o-optimize/init.o
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-dpmem.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-msg.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-mp.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-part.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-signal.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-timer.rel
>> /home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-rtmon.rel
>> librtemscpu.a(printk.o): In function `vprintk':
>> /home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon1/exec/
>> libcsupport/../../../../../../rtems-4.6.0pre5/cpukit/libcsupport/src/
>> printk.c:142: undefined reference to `BSP_output_char'
>> ..... many more of the same
>> I cannot find BSP_output_char defined for the sparc bsp. Any
>> suggestions as to what I am missing or doing wrong woulde be
>> appreciated.
> I think that you need to suply the function in order to give a printk
> a char function unknown
> for your BSP.
> In pc386 it is supplied by default with a putchar in console.
Thanks for the response, Fernando! It seems so simple when you out it
that way :-)
  I found and example in one of the other BSP's and it seems to work.
>>  From reading previous posting and the source code, it seemed like I
>> should be able to run the telnetd daemon by simply calling
>> main_telnetd().   This is my real goal, if anyone can tell me how to
>> start it, that would be appreciated too.
> Don't forget to call before to register telnetd ( in the same file
> telnetd.c) in order to add the
> shell command at the commands list.
I'm still struggling here. Do you have a brief example of how to set up
a simple telnetd example? I get to run and when I connect from another
system via telnet, it "connects", but immediately closes the
connection. Great progress, but still not very satisfying :-)  I have
not found any examples of how to set up the "shell". If yo have any
suggestions, they would be most welcome.
Thank you - Jerry
> BRGDS.
>> - thanks - Jerry
