Question about -ansi flag, and different size of struct from C and C++
Oleg Ivanov Belinus at zelax.ru
Mon Dec 15 15:34:15 UTC 2003
Ralf Corsepius пишет:
>On Mon, 2003-12-15 at 15:18, Oleg Ivanov wrote:
>>   Thanks a lot!
>>   Yes, I also see #pragma warning: ignoring pragma: even if I compiling
>>with or without -ansi flag.
>>   And another thing, I compile code under two targets Motorola 68360
>>and 860.
>>   In one point compiler aligned all struct to 4, in other every struct
>>member.
>>   That mean size of struct
>>   struct dummy {
>>      int var1;
>>      short var2;
>>      int var3;
>>      short var4;
>>   on motorola 68360 will be 12 byte, and on 860 - 16 byte...
>>Is it also target dependent ?
>Yes, it is.
>But what is your actual problem? Size (eg. allocating large arrays), or
>IO?
>Ralf
It's more IO, but and size too.
 From Rtems I controle hardware that accept about 30  packets(each with
fix length) with several(to 32) commands with parameters(full packet
send even all or only one command is set), so I think that easy way to
handle this zoo is to make a struct to each packet. But as I say got
this problem, size changes and command rejected, and also packet work
only from C, from C++ it not work. It's work only when I ommit -ansi flag.
