Question about -ansi flag, and different size of struct from C and C++
Camilo Alejandro Arboleda CamiloAlejo at netscape.net
Mon Dec 15 21:06:10 UTC 2003
There is a command line option of GCC (-fpack-struct) that makes *all*
your structs packet. It could make your code binary incompatible with
pre-comiled libraries.
Belinus at zelax.ru wrote:
>    Hello list,
>    I have a problem. I defined struct like:
>        struct dummy {
>          int var1;
>          short var2;
>          int var3;
>       } __attribute__ ((packed));
>    and access to it from C and C++ code.
>    The problem is that size from C is 10 bytes and from C++ is 12
> bytes, I couldn't make that C++ packed that struct, exept removing
> -ansi flag from compiler string.
>    So I have two question, is there another method to ask C++ packed
> struct, and do we really need -ansi flag to compile rtems ?
>    Thanks
Your favorite stores, helpful shopping tools and great gift ideas.
Experience the convenience of buying online with Shop at Netscape!
http://shopnow.netscape.com/
