Bug in rtems_task_set_priority()
Thomas Rauscher
trauscher at loytec.com
Tue Dec 23 17:21:07 UTC 2003
Hi,
we've discovered a bug in rtems_task_set_priority() in RTEMS-4.5.0.
The problem seems to be in the mainline too, but I cannot test this.
It occurs if a task owning a non-priority discipline semaphore
lowers its priority or gets its priority lowered by another task.
Its priority is not lowered then at all.
The problem is that for a task owning only fifo and/or priority
semaphores,
the task priority is not changed immediately or at least when the
'resource_count' in the thread control structure is decremented back to
zero.
The patch in the attachment is a first attempt to address this problem.
Feel free to comment it.
It creates a 'priority_resource_count' variable
in the thread control structure which is incremented only for
priority-discipline semaphores. All priority changing code uses the
'priority_resource_count' instead of 'resource_count' then.
As far as I can tell, 'resource_count' is only used for priority
inheritance/ceiling,
so the second variable is not strictly necessary. If the patch is OK so
far,
only one counter for priority-discipline semaphores is required.
I've also attached a testcase demonstrating the problem.
Best regards,
Thomas Rauscher
Thomas Rauscher
LOYTEC electronics GmbH
Stolzenthalergasse 24/3
A-1080 Wien
Austria/Europe
www.loytec.com
Phone: +43-1-4020805-15
FAX: +43-1-4020805-99
Type: text/x-csrc
Desc:
URL: <http://lists.rtems.org/pipermail/users/attachments/20031223/a673a0c4/attachment.bin>
Index: itron/src/chg_pri.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/itron/src/chg_pri.c,v
retrieving revision 1.1.1.1
diff -r1.1.1.1 chg_pri.c
56c56
< if ( the_thread->resource_count == 0 ||
> if ( the_thread->priority_resource_count == 0 ||
Index: posix/src/pthread.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/posix/src/pthread.c,v
retrieving revision 1.1.1.2
diff -r1.1.1.2 pthread.c
79c79
116c116
Index: rtems/src/tasksetpriority.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/rtems/src/tasksetpriority.c,v
diff -r1.1.1.1 tasksetpriority.c
89c89
Index: score/include/rtems/score/thread.h
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/include/rtems/score/thread.h,v
retrieving revision 1.2
diff -r1.2 thread.h
163a164
> unsigned32 priority_resource_count;
196a198
Index: score/src/coremutex.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/src/coremutex.c,v
diff -r1.1.1.2 coremutex.c
75a76,84
> switch ( the_mutex->Attributes.discipline ) {
> case CORE_MUTEX_DISCIPLINES_FIFO:
> case CORE_MUTEX_DISCIPLINES_PRIORITY:
> break;
> case CORE_MUTEX_DISCIPLINES_PRIORITY_CEILING:
> case CORE_MUTEX_DISCIPLINES_PRIORITY_INHERIT:
> _Thread_Executing->priority_resource_count++;
> break;
Index: score/src/coremutexseize.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/src/coremutexseize.c,v
diff -r1.1.1.1 coremutexseize.c
75a76,84
> break;
> break;
Index: score/src/coremutexsurrender.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/src/coremutexsurrender.c,v
diff -r1.1.1.1 coremutexsurrender.c
105c105,110
< if ( holder->resource_count == 0 &&
> _Thread_Executing->priority_resource_count--;
> /* !!TR: Fix docu on priority inheritance 8.2.3 3rd paragraph:
> * Use "binary semaphore using priority inheritance" instead
> * of "binary semaphore".
> if ( holder->priority_resource_count == 0 &&
130a136,144
> break;
> the_thread->priority_resource_count++;
> break;
Index: score/src/threadinitialize.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/src/threadinitialize.c,v
diff -r1.2 threadinitialize.c
159a160
> the_thread->priority_resource_count= 0;
Index: score/src/threadreset.c
RCS file: /data/prj_sw/cvs/rtems/c/src/exec/score/src/threadreset.c,v
diff -r1.1.1.1 threadreset.c
45a46
> the_thread->priority_resource_count = 0;
