Even more stupid questions
Scott Newell newell at cei.net
Mon Dec 29 22:38:02 UTC 2003
I think there's a bug in the docs at:
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/ht
ml/c_user/c_user00135.html
The header file shows that there are three args, not two.  I also can not
explain why the documentation shows an extra parens.
Is there a recommended reading list to effectively get started with RTEMS?
I'm tripping over stuff like the "MANAGERS=" line in the makefile--I've not
run across any docs on it, but I learned the hard way that the timer
manager don't go unless timer is in that list.
newell
