How do I download now
Chris Caudle chris at chriscaudle.org
Tue Dec 30 22:26:28 UTC 2003
On Tue December 30 2003 3:58 pm, Chris Caudle wrote:
> There are two steps involved.
Forgot to go back and fill in the second step.
Once the BIOS has the list of devices which support interrupt 13 block
access, you have to pick the order to try to boot.
That is BIOS specific, but for most PC style machines, that means you have
to have a keyboard and monitor connected (or serial terminal if serial
console is supported by the BIOS), and you hit some key during power up to
cause the BIOS to jump into a configuration program instead of booting.
Usually there will be some kind of menu system, and you find the entry for
boot order and select which device should be primary boot.
Chris Caudle
