How do I download now
Angelo Fraietta afraiett at bigpond.net.au
Wed Dec 31 00:28:56 UTC 2003
I used to use GrUB but now use eXtender becuase you don't need to make
boot floppies and the likes. You do, however, have to boot to DOS first.
I found this extremely usefull because I was able to run it from the
autoexec.bat, which allowed me to run a disk checking program and
another DOS based program before starting RTEMS.
Chris Caudle wrote:
>On Tue December 23 2003 6:34 am, Chris Sparks wrote:
>>I would like to use my Disk On Chip to load my RTEMS application or even
>>use it for my loader.
>Not a problem.
>You still need GrUB on a floppy to get started.  There are other ways, but
>that will be the easiest.
>Go to the GrUB web page, and check the documentation, you will need to be
>familiar with some commands for installing the first part of GrUB onto the
>master boot record (the first sector).
>http://www.gnu.org/software/grub/grub.html
>>Since I am using the PC 686 BSP I would like to know more of how the
>>BIOS knows where to go to boot from.
>There are two steps involved.  The first is figuring out which devices can
>be accessed as block devices. For devices on the motherboard, that support
>is typically included in the BIOS ROM of the motherboard.
>For added devices, there are a set of defined addresses where cards can
>provide their own support routines to be accessed from BIOS (known as the
>Option ROM).
>For block devices, like hard drives, the option ROM provides a service
>routine for interrupt 13, which is a software interrupt used by the BIOS
>for block access.  I forget the details, but from what I remember you can
>think of it as a wrapper around an IDE programmed I/O style interface.
>Disk-On-Chip modules provide an option ROM which contains a driver for
>accessing the Flash ROM within the D-O-C as a block device.  The driver
>also has additional features, like sector remapping with write wear
>levelling, I think bad sector remapping is handled by the driver, etc.
>That means that if you use D-O-C for more than just boot, you need the
>driver compiled into your application.
>CompactFlash is typically connected to an IDE style controller, so I think
>you shouldn't notice any difference between CF and a real hard drive.
>To get GrUB onto either, you follow the instructions in the GrUB
>documentation for installing GrUB onto a hard drive.  That typically
>involves booting a floppy (or some other media with GrUB on it, such as an
>extra hard drive that you have already installed GrUB on), and issuing
>commands at the GrUB command prompt to copy the boot sector from the media
>you just booted onto the new media.
>I think you also need to copy some additional files to the device.  The
>details are covered in the documentation.
>http://www.gnu.org/software/grub/manual/html_mono/grub.html#Installation
>hope that helps,
>Chris Caudle
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
