Building RTEMS
Chris Sparks mrada at catalina-inter.net
Wed Dec 3 05:28:35 UTC 2003
Ok I figured out what I did wrong and I was not passing the right
parameter into configure so
it couldn't find i386-rtems-gcc.  So I went ahead fixed my mistake and
the build still crashes.
It wants me to do a make dist-clean or some such action.
My question really is what specifically do I need to do to get up to
pre5.  I have pre4 and I
didn't want to have to download everything.  What exactly changed that I
need to upgrade to?
Thanks,
chris Sparks
Ralf Corsepius wrote:
>On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
>>Hello Ralf,
>>>On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
>>>>Hi,
>>>>It has been quiet on this list for some time now....
>>>>I managed to get a half decent Fedora up and running and was going
>>>>through instructions to build
>>>>RTEMS.  I am using the Getting started with the C++ users manual and I
>>>>got several errors.
>>>>The first was "checking for i386-gcc... no"
>>>>which I know I set the path right.
>>>Well, though you say so, I doubt it.
>>What is strange is that the native gcc is "gcc" not "i386-gcc" and the
>>target gcc is "i386-rtems-gcc" so
>>I don't know what this "i386-gcc" is.
>I don't know what you are doing ;-)
>The native C-compiler must be called cc or gcc and must be in $PATH
>which gcc
>should tell you if this applies.
>>>>The second came from configure, "no acceptable cc found in $PATH
>>>>So what is going on here?
>>>Make sure to have
>>>* the native toolchain installed
>>>* the target toolchain installed
>>>And to have set up $PATH correctly.
>>I have the "/opt/rtems/bin" before all others in my path.  Is this wrong?
>It depends on which of the RTEMS toolchains you have installed.
>It could be one of these:
>/opt/rtems/bin (Used until now),
>/opt/rtems-4.6/bin (Probably used by the final 4.6-release) or
>/opt/rtems-4.7/bin (To be used by future snapshots).
>Assuming you want to build i386-rtems, you should have one of
>/opt/rtems/bin/i386-rtems-gcc
>/opt/rtems-4.6/bin/i386-rtems4.6-gcc
>/opt/rtems-4.7/bin/i386-rtems4.7-gcc
>Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you have.
>Then configure RTEMS using the string that prefixes the target gcc you have:
>Eg.
>If having /opt/rtems/bin/i386-rtems-gcc, the  use
>configure --target=i386-rtems [options]
>If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
>configure --target=i386-rtems4.6 [options]
>Ralf
