Building RTEMS
Chris Sparks
mrada at catalina-inter.net
Thu Dec 4 06:05:21 UTC 2003
Well I noticed that only the RTEMS part changed for pre5 and not the
tools so I installed
the patch to pre4 to make pre5 and my building seems to be progressing
pretty nicely.
I am getting excited that I am getting closer to my goal of getting a
sample program to run.
May not get to it until I get back from SIGAda conference this year. Is
anyone going? I'd
like to swap RTEMS stories.
Has anyone done any graphics (VGA, SVGA, whatever) with RTEMS? I need it.
Chris Sparks
Chris Sparks wrote:
> Ok I figured out what I did wrong and I was not passing the right
> parameter into configure so
> it couldn't find i386-rtems-gcc. So I went ahead fixed my mistake and
> the build still crashes.
> It wants me to do a make dist-clean or some such action.
> My question really is what specifically do I need to do to get up to
> pre5. I have pre4 and I
> didn't want to have to download everything. What exactly changed that
> I need to upgrade to?
> Thanks,
> chris Sparks
> Ralf Corsepius wrote:
>> On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
>>> Hello Ralf,
>>>> On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
>>>>> Hi,
>>>>> It has been quiet on this list for some time now....
>>>>> I managed to get a half decent Fedora up and running and was going
>>>>> through instructions to build
>>>>> RTEMS. I am using the Getting started with the C++ users manual
>>>>> and I got several errors.
>>>>> The first was "checking for i386-gcc... no"
>>>>> which I know I set the path right.
>>>> Well, though you say so, I doubt it.
>>> What is strange is that the native gcc is "gcc" not "i386-gcc" and
>>> the target gcc is "i386-rtems-gcc" so
>>> I don't know what this "i386-gcc" is.
>> I don't know what you are doing ;-)
>> The native C-compiler must be called cc or gcc and must be in $PATH
>> which gcc
>> should tell you if this applies.
>>>>> The second came from configure, "no acceptable cc found in $PATH
>>>>> So what is going on here?
>>>> Make sure to have
>>>> * the native toolchain installed
>>>> * the target toolchain installed
>>>> And to have set up $PATH correctly.
>>> I have the "/opt/rtems/bin" before all others in my path. Is this
>>> wrong?
>> It depends on which of the RTEMS toolchains you have installed.
>> It could be one of these:
>> /opt/rtems/bin (Used until now), /opt/rtems-4.6/bin (Probably used by
>> the final 4.6-release) or
>> /opt/rtems-4.7/bin (To be used by future snapshots).
>> Assuming you want to build i386-rtems, you should have one of
>> /opt/rtems/bin/i386-rtems-gcc
>> /opt/rtems-4.6/bin/i386-rtems4.6-gcc
>> /opt/rtems-4.7/bin/i386-rtems4.7-gcc
>> Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you have.
>> Then configure RTEMS using the string that prefixes the target gcc
>> you have:
>> Eg. If having /opt/rtems/bin/i386-rtems-gcc, the use
>> configure --target=i386-rtems [options]
>> If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
>> configure --target=i386-rtems4.6 [options]
>> Ralf
