Building RTEMS
gregory.menke at gsfc.nasa.gov
Thu Dec 4 14:20:13 UTC 2003
Chris Sparks writes:
> Well I noticed that only the RTEMS part changed for pre5 and not the
> tools so I installed
> the patch to pre4 to make pre5 and my building seems to be progressing
> pretty nicely.
> I am getting excited that I am getting closer to my goal of getting a
> sample program to run.
> May not get to it until I get back from SIGAda conference this year. Is
> anyone going? I'd
> like to swap RTEMS stories.
> Has anyone done any graphics (VGA, SVGA, whatever) with RTEMS? I need it.
Rosimildo Da Silva did a port of SVGAlib to RTEMS, but a quick check
of his project page shows its offline- at least from my workstation.
Joel might know where his page is, but I do have the tar.gz and diff
file if its not available elsewhere. I was hoping to give a try at
porting it to PowerPC over the holidays, we have a cpci vga board
thats otherwise unused. Its worth mentioning that it appears Mesa
OpenGL can use svgalib as a driver, so its not entirely impossible
that it could be ported to RTEMS too. Interesting idea...
gregm
> Chris Sparks
> Chris Sparks wrote:
> > Ok I figured out what I did wrong and I was not passing the right
> > parameter into configure so
> > it couldn't find i386-rtems-gcc. So I went ahead fixed my mistake and
> > the build still crashes.
> > It wants me to do a make dist-clean or some such action.
> > My question really is what specifically do I need to do to get up to
> > pre5. I have pre4 and I
> > didn't want to have to download everything. What exactly changed that
> > I need to upgrade to?
> > Thanks,
> > chris Sparks
> > Ralf Corsepius wrote:
> >> On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
> >>> Hello Ralf,
> >>>> On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
> >>>>> Hi,
> >>>>> It has been quiet on this list for some time now....
> >>>>> I managed to get a half decent Fedora up and running and was going
> >>>>> through instructions to build
> >>>>> RTEMS. I am using the Getting started with the C++ users manual
> >>>>> and I got several errors.
> >>>>> The first was "checking for i386-gcc... no"
> >>>>> which I know I set the path right.
> >>>> Well, though you say so, I doubt it.
> >>> What is strange is that the native gcc is "gcc" not "i386-gcc" and
> >>> the target gcc is "i386-rtems-gcc" so
> >>> I don't know what this "i386-gcc" is.
> >> I don't know what you are doing ;-)
> >> The native C-compiler must be called cc or gcc and must be in $PATH
> >> which gcc
> >> should tell you if this applies.
> >>>>> The second came from configure, "no acceptable cc found in $PATH
> >>>>> So what is going on here?
> >>>> Make sure to have
> >>>> * the native toolchain installed
> >>>> * the target toolchain installed
> >>>> And to have set up $PATH correctly.
> >>> I have the "/opt/rtems/bin" before all others in my path. Is this
> >>> wrong?
> >> It depends on which of the RTEMS toolchains you have installed.
> >> It could be one of these:
> >> /opt/rtems/bin (Used until now), /opt/rtems-4.6/bin (Probably used by
> >> the final 4.6-release) or
> >> /opt/rtems-4.7/bin (To be used by future snapshots).
> >> Assuming you want to build i386-rtems, you should have one of
> >> /opt/rtems/bin/i386-rtems-gcc
> >> /opt/rtems-4.6/bin/i386-rtems4.6-gcc
> >> /opt/rtems-4.7/bin/i386-rtems4.7-gcc
> >> Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you have.
> >> Then configure RTEMS using the string that prefixes the target gcc
> >> you have:
> >> Eg. If having /opt/rtems/bin/i386-rtems-gcc, the use
> >> configure --target=i386-rtems [options]
> >> If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
> >> configure --target=i386-rtems4.6 [options]
> >> Ralf
