Building RTEMS
Chris Sparks
mrada at catalina-inter.net
Fri Dec 5 04:59:01 UTC 2003
I just re"gmaked" the pc586 bsp and it went through ok. Only had one
kernel dump from Fedora.
At least I seem to be going in a forward direction.
Chris Sparks wrote:
> Hi all,
> Ok I got this:
> i386-rtems-gcc --pipe -DHAVE_CONFIG_H -isystem
> ../../../.././pc586/lib/include -Isrc -mcpu=pentium -O4 -g -Wall
> -o o-optimize/tcsetattr.o -c
> ../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcsetattr.c
> -o o-optimize/tcdrain.o -c
> ../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcdrain.c
> -o o-optimize/tcflow.o -c
> ../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcflow.c
> -o o-optimize/tcflush.o -c
> ../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcflush.c
> -o o-optimize/tcgetprgrp.o -c
> ../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcgetprgrp.c
> i386-rtems-gcc: Internal error: Segmentation fault (program as)
> Please submit a full bug report.
> See <URL:http://gcc.gnu.org/bugs.html> for instructions.
> gmake[4]: *** [o-optimize/tcgetprgrp.o] Error 1
> gmake[4]: Leaving directory
> `/usr/src/redhat/BUILD/build-rtems/i386-rtems/c/pc586/exec/libcsupport'
> gmake[3]: *** [all-recursive] Error 1
> gmake[3]: Leaving directory
> `/usr/src/redhat/BUILD/build-rtems/i386-rtems/c/pc586/exec'
> gmake[2]: *** [all-recursive] Error 1
> Where do I go from here?
> Chris
> Chris Sparks wrote:
>> Well I noticed that only the RTEMS part changed for pre5 and not the
>> tools so I installed
>> the patch to pre4 to make pre5 and my building seems to be
>> progressing pretty nicely.
>> I am getting excited that I am getting closer to my goal of getting a
>> sample program to run.
>> May not get to it until I get back from SIGAda conference this year.
>> Is anyone going? I'd
>> like to swap RTEMS stories.
>> Has anyone done any graphics (VGA, SVGA, whatever) with RTEMS? I
>> need it.
>> Chris Sparks
>> Chris Sparks wrote:
>>> Ok I figured out what I did wrong and I was not passing the right
>>> parameter into configure so
>>> it couldn't find i386-rtems-gcc. So I went ahead fixed my mistake
>>> and the build still crashes.
>>> It wants me to do a make dist-clean or some such action.
>>> My question really is what specifically do I need to do to get up to
>>> pre5. I have pre4 and I
>>> didn't want to have to download everything. What exactly changed
>>> that I need to upgrade to?
>>> Thanks,
>>> chris Sparks
>>> Ralf Corsepius wrote:
>>>> On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
>>>>> Hello Ralf,
>>>>>> On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
>>>>>>> Hi,
>>>>>>> It has been quiet on this list for some time now....
>>>>>>> I managed to get a half decent Fedora up and running and was
>>>>>>> going through instructions to build
>>>>>>> RTEMS. I am using the Getting started with the C++ users manual
>>>>>>> and I got several errors.
>>>>>>> The first was "checking for i386-gcc... no"
>>>>>>> which I know I set the path right.
>>>>>> Well, though you say so, I doubt it.
>>>>> What is strange is that the native gcc is "gcc" not "i386-gcc" and
>>>>> the target gcc is "i386-rtems-gcc" so
>>>>> I don't know what this "i386-gcc" is.
>>>> I don't know what you are doing ;-)
>>>> The native C-compiler must be called cc or gcc and must be in $PATH
>>>> which gcc
>>>> should tell you if this applies.
>>>>>>> The second came from configure, "no acceptable cc found in $PATH
>>>>>>> So what is going on here?
>>>>>> Make sure to have
>>>>>> * the native toolchain installed
>>>>>> * the target toolchain installed
>>>>>> And to have set up $PATH correctly.
>>>>> I have the "/opt/rtems/bin" before all others in my path. Is this
>>>>> wrong?
>>>> It depends on which of the RTEMS toolchains you have installed.
>>>> It could be one of these:
>>>> /opt/rtems/bin (Used until now), /opt/rtems-4.6/bin (Probably used
>>>> by the final 4.6-release) or
>>>> /opt/rtems-4.7/bin (To be used by future snapshots).
>>>> Assuming you want to build i386-rtems, you should have one of
>>>> /opt/rtems/bin/i386-rtems-gcc
>>>> /opt/rtems-4.6/bin/i386-rtems4.6-gcc
>>>> /opt/rtems-4.7/bin/i386-rtems4.7-gcc
>>>> Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you
>>>> have.
>>>> Then configure RTEMS using the string that prefixes the target gcc
>>>> you have:
>>>> Eg. If having /opt/rtems/bin/i386-rtems-gcc, the use
>>>> configure --target=i386-rtems [options]
>>>> If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
>>>> configure --target=i386-rtems4.6 [options]
>>>> Ralf
