Bug in mon-manager.c in Rtems 4.6pre4
Fri Dec 5 12:11:02 UTC 2003
Wilfried Busalski wrote:
>Hi..
>I think there is a Bug in the mon-monager.c.
>I use RTEMS4.6pre4 on a PowerPC MPC565 Board. The content of Memory Address
>0x0000000 is not 0x00000000 but 0x4B6C6175. In that case the 'rtems-monitor'
>brings by command 'queue' an exeception. If the content is 0x00000000 the
>command will run without exeception.
>Is this behavoir volitional or a Bug ?
I'm prone to say bug since it sounds like a derefence of a NULL
pointer.  Can you
identify the line of code in question?
>with best regards
>Wilfried Busalski
--joel
