Coldfire debug
Alan Cudmore Alan.P.Cudmore at nasa.gov
Fri Dec 12 18:41:30 UTC 2003
I use RTEMS and gdb 5.2 with the coldfire/BDM patches from the
sourceforge site. It works well. I will probably put the RTEMS GDB
patches in next. One of the things I am missing is the stack context
for each task.
Alan
On Dec 12, 2003, at 7:12 AM, Joel Sherrill wrote:
> Paul Whitfield wrote:
>> silverio.di at qem.it wrote:
>>> Hi to all,
>>> this topic could be a little OT but I consider your great experience
>>> with GNU tools so I try to submit you that:
>>> I would debug a very little program in my Coldfire 5282 target,
>>> compiled with rtems m68k-rtems-gcc. What are the available ways to
>>> do that
>>> 1) exist a stub program to write in 5282 flash which permit
>>> debugging with
>>>     m68k-rtems-gdb debugger via serial cable ?
>> RTEMS 4.6.0 appears to have support for the gdb serial stub,
>> however I have not used it.
>>> 2) m68k-rtems-gdb support the coldfire BDM port ?
>> See:
>> http://sourceforge.net/projects/bdm/
>> For a version of GDB with bdm support that will work
>> with RTEMS.
> RTEMS makes no special assumptions with gdb so whatever gdb connects
> to your target is OK.  Any BDM enabled version is what you want.
>> Regards
>> Paul
