RTEMS with RH 9.0
Till Straumann strauman at SLAC.Stanford.EDU
Mon Dec 22 18:41:53 UTC 2003
Chris Sparks wrote:
> Hi everyone,
> I have abandoned trying to get RTEMS built on Fedora 1.0 and was
> wondering if anyone
> has been successful with RH 9.0?
> Thanks,
> Chris
Sure.
I can't really believe this matters. Just make sure
  a) you have the correct toolchain version installed.
     In particular, you *need* the autotools version as
     required by RTEMS.
  b) make sure the autotools required by RTEMS are in your PATH
     and not the version that comes with your distro...
I never really had an issue with my host OS version. Usually
it is an old automake in my PATH that causes trouble...
HTH
-- Till
