RTEMS with RH 9.0 (How do I download now)
Chris Sparks
mrada at catalina-inter.net
Mon Dec 22 23:35:42 UTC 2003
Till hit the nail on the head. I now don't need RH 9.0. Fedora 1.0
works ok.
I got all the way through the hello_world_c application and now I need
to know how
to download it.
The instructions are vague if best "is very dependent on the
BOARD_SUPPORT_PACKAGE
selected." What does that mean? Where do I go from here?
Till Straumann wrote:
> Chris Sparks wrote:
>> Hi everyone,
>> I have abandoned trying to get RTEMS built on Fedora 1.0 and was
>> wondering if anyone
>> has been successful with RH 9.0?
>> Thanks,
>> Chris
> Sure.
> I can't really believe this matters. Just make sure
> a) you have the correct toolchain version installed.
> In particular, you *need* the autotools version as
> required by RTEMS.
> b) make sure the autotools required by RTEMS are in your PATH
> and not the version that comes with your distro...
> I never really had an issue with my host OS version. Usually
> it is an old automake in my PATH that causes trouble...
> HTH
> -- Till
