HOE to compile/build RTEMS tests samples?
Wed Dec 31 00:26:05 UTC 2003
Alex wrote:
>Hi
>In ...  ../c/src/tests/psxtests there are posix threads... I wopuld like to build them..
>When I execute
>./configure I see an error saying:
>Missing RTEMS_BSP. How to supply this info?
>Which are the right steps to build this samples?
I suspect you are trying to configure from that level of the tree.
Enable tests and
posix at the top level configure.
>Thanks
>Alexandre
>(Beginner)
