rtems-ss-20030128 problem
Francesco Poletti
fpoletti at libero.it
Mon Feb 3 16:17:53 UTC 2003
Hy, in the last version of the snapshot I found this error: in the Makefile.am, of the shmdr directory, there was:
all-local: $(ARCH) $(PREINSTALL_FILES) $(PGM) $(TMPINSTALL_FILES)
When I build rtems arm-rtems-gcc don't found shm_driver.h I revert the order of all local in:
all-local: $(ARCH) $(PREINSTALL_FILES) $(TMPINSTALL_FILES) $(PGM)
and now works. Is a mine error or a global error?
Another problems if I put in the configure the options --enable-tests I have this error message:
checking for gmake... gmake
checking for RTEMS Version... ss-20030128
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-rtems
checking target system type... arm-unknown-rtems
checking rtems target cpu... arm
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking for arm-rtems-strip... arm-rtems-strip
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for RTEMS_BSP... arm_bare_bsp
checking if cpu arm is supported... yes
checking for style of include used by gmake... GNU
checking for arm-rtems-gcc... arm-rtems-gcc
checking for arm-rtems-gcc... (cached) arm-rtems-gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether arm-rtems-gcc accepts -g... yes
checking for arm-rtems-gcc option to accept ANSI C... none needed
checking dependency style of arm-rtems-gcc... gcc3
checking how to run the C preprocessor... arm-rtems-gcc -E
checking whether arm-rtems-gcc accepts -specs... yes
checking whether arm-rtems-gcc accepts --pipe... yes
checking for arm-rtems-ar... arm-rtems-ar
checking for arm-rtems-as... arm-rtems-as
checking for arm-rtems-ld... arm-rtems-ld
checking for arm-rtems-nm... arm-rtems-nm
checking for arm-rtems-ranlib... arm-rtems-ranlib
checking for arm-rtems-objcopy... arm-rtems-objcopy
checking for arm-rtems-size... arm-rtems-size
checking for arm-rtems-strip... (cached) arm-rtems-strip
checking for make/custom/arm_bare_bsp.cfg... yes
checking whether to build rtems++... no
configure: error: conditional "am__fastdepCXX" was never defined.
Usually this means the macro was only invoked conditionally.
configure: error: /bin/sh '../../../../../../rtems-ss-20030128/c/src/tests/libtests/configure' failed for libtests
configure: error: /bin/sh '../../../../../rtems-ss-20030128/c/src/tests/configure' failed for tests
gmake[2]: *** [arm_bare_bsp] Error 1
May anyone help me?
Thanks to all Francesco
