RTEMS SS-20030128 available
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Feb 4 14:18:24 UTC 2003
Jack Cawkwell wrote:
> Joel,
> If you can find the disk space for 2 images that would be good enough
> for me and probably most newbies. I presumme that the old cd-image is
> gone, and will wait for your announcement of the new cd image being
> available. If anyone wants a real plastic CD, I would be happy to burn
> them and send them in the post :-) , once I get a good image.
Once a stable release is available, OAR is planning on making them
available. We didn't want to duplicate the "CD of the day."
> Thanks, Jack
> joel.sherrill at oarcorp.com writes:
> >> Joel,
> >> Well that explains things. I assume that you have good reasons for not
> >> leaving the old (working) CD version in place, while you make the new
> >one
> >> somewhere else?
> >Yep. It eats disk space a gigabyte at a time. :)
> >> I am not sure how to work with this, could you provide and publicise a
> >> stable period when a cd download it going to be kosher? An 8 or 9 hour
> >> download is not something I can do on the spur of the moment ;-).
> >How about I try to build a "new tree" in a separate directory and then
> >swap the old and new? I could even go so far as to make "current-cd"
> >as a symlink to a cd-date. That would make it possible to keep two
> >images online. I don't want to keep N images online but 2 is OK.
> >When the next modifcation happens, I will try that:
> >--joel
joel at OARcorp.com On-Line Applications Research
