Passing vector number (was Re: API modification request)
    Sergei Organov
    osv at javad.ru
    Tue Feb  4 14:25:18 UTC 2003
Eric Valette <eric.valette at free.fr> writes:
> Sergei Organov wrote:
> > Please keep in mind that unfortunately you don't see all the code. There
> > could be proprietary code that relies on features you change...
> Using such argument, you will never change anything.
No. It only implies that one should better think "I better don't change this
unless I have valuable reasons to" instead of "Why don't change this if
nobody seems to use it anyway?".
> I think on the contrary that people not submitting their code/improvement
> should be biten as hard as possible so that next time they submit (at least
> part of) their code :-)
1. There is very small reason to submit a code if it will only run on a
   proprietary hardware that nobody can get anyway.
2. Company policy may prevent submission. Most probably poor programmer bitten
   by you hadn't established the policy :-(
BR,
Sergei.
