Passing vector number (was Re: API modification request)
    Eric Valette
    eric.valette at free.fr
    Tue Feb  4 14:47:01 UTC 2003
Sergei Organov wrote:
> Eric Valette <eric.valette at free.fr> writes:
>>>Please keep in mind that unfortunately you don't see all the code. There
>>>could be proprietary code that relies on features you change...
>>Using such argument, you will never change anything.
> No. It only implies that one should better think "I better don't change this
> unless I have valuable reasons to" instead of "Why don't change this if
> nobody seems to use it anyway?".
Hey
	1) there was a smiley in my message!
	2) I think we have come to the conclusion that a void* is indeed a more
powerfull API with little performance impact (as you can cast the void*
to an int to get your vector number). Concerning portability, as I
already mentionned often in this newgroup, *IRQ HANDLING SHOULD REMAIN
BSP SPECIFIC* meaning that you are not forced to change the API at all
on non standart platform. If you just want to benefit the enhancement
made by others, then this will cost you more and more time due to
API/build enevironment cahnges that will occur.
> 1. There is very small reason to submit a code if it will only run on a
>    proprietary hardware that nobody can get anyway.
OK but if an API prevent to port rtems easilly to a hardware that is not
too much exotic, maybe it means that the API is flowed...
> 2. Company policy may prevent submission. Most probably poor programmer bitten
>    by you hadn't established the policy :-(
Do you know Canon IP policy? Do you know the patenting pressure I had to
fight all those past 7 years. So believe me, you can change things if
you explain that submitting code cost less money and do not divulgate
company know how...
    __
   /  `                   	Eric Valette
  /--   __  o _.          	6 rue Paul Le Flem
(___, / (_(_(__         	35740 Pace
Tel: +33 (0)2 99 85 26 76	Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
