ISR Argument Proposal Request
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Tue Feb 4 20:44:19 UTC 2003
Eric Valette writes:
 > gregory.menke at gsfc.nasa.gov wrote:
 >  > On the R3000, the
 > > difference between an exception and an interrupt is very small and
 > > handling them all in one routine with one type of stack frame has some
 > > advantages.
 > On the other hand, this is false on many other processors as nowadays
 > IRQ dispatch, masking, prioritizing is usually done by programmable
 > interrupt controller. I would tend to agree that in general, raw
 > execption handling and irq handling are quite similar but we are not
 > talking about this here.
 > Another example : why would I like to store 255 void when I just have
 > seven or fifteen different irqs. Why shoul I push a frame when it is
 > used only by exception code and not irqs...
I think we're in violent agreement- I'm not advocating not fancying up
the interrupt/exception handling and trying to make it consistent
across as many bsp's as possible, nor am I advocating the mips
approach as being somehow better or particularly advantageous.  I will
say however, that it may well be desirable to allow some bsp's to
remain primitive if its appropriate/desirable given the architecture.
That said, the principal overhead in the mips int/exception handling
is in the stack frame setup/teardown, so I think integrating the mips
bsp's into whatever model ends up being used should be a clear win and
I'll be happy to work on it.
Gregm
