Network Routing Bug
Mike Siers
mikes at poliac.com
Thu Feb 6 15:09:24 UTC 2003
Hi All,
I think I found a small bug in the RTEMS version of the function
m_copyback(). I am using the rtems-ss-20021118 snapshot.
The RTEMS version of the m_copyback is changing the m_len value of
the mbuf. I looked into the source from another BSD system and
the mbuf length is not changed inside this function.
The m_copyback function is only being used in the net/rtsock.c file.
So I think this problem is only visable under certain routing table
conditions.
Below is my patch to fix the problem. The uipc_mbuf.c file is located
in the cpukit/libnetworking/kern directory. Please review and let
me know if you think this the correct fix.
Thanks
Mike Siers
--- uipc_mbuf.c Sat Nov 2 10:27:43 2002
+++ uipc_mbuf.new Thu Feb 6 08:50:46 2003
@@ -755,7 +755,7 @@
off = 0;
totlen += mlen;
if (len == 0) {
- m->m_len = mlen;
+ /* m->m_len = mlen; */
break;
if (m->m_next == 0) {
@@ -767,7 +767,7 @@
n->m_len = min(MLEN, len);
m->m_next = n;
- m->m_len = mlen;
m = m->m_next;
/*out:*/
