SYSV / EABI compliance
Chris Johns cjohns at cybertec.com.au
Tue Feb 18 02:53:22 UTC 2003
Till Straumann wrote:
> I encountered one problem, however: Certain parts of
> the system (mostly BSP specific stuff, but also
> cpukit/libnetworking/kern/kern_sysctl.o) access
> linker defined symbols in the following way:
The sysctl related code is in:
  cpukit/libnetworking/sys/linker_set.h
and needs a linker script change to collect all the variables into an array.
> /* with -msdata=eabi, the compiler assumes
>  * this variable's address will be linked
>  * in the short data area.
> extern int some_linker_defined_address;
> /* use the address here */
> yyy( (unsigned) & some_linker_defined_address )
> When compiling with -msdata=eabi, a linker error results
> because the compiler generates code who tries to locate
> the address in a short data area while it is actually
> an absolute address.
> I solved this by declaring the bogus variable
> (only the address has a meaning) as an array of unknown
> size:
> /* compiler doesn't know the size, hence access is
>  * through an absolute address
> extern int some_linker_defined_address[];
> yyy( (unsigned)some_linker_defined_address )
> Does anyone have a better solution / suggestion?
I do not understand what you needed to do for sysctl ?
Did you have to provide definitions for each sysctl variable that uses the TEXT_SET
macro ?
  Chris Johns, cjohns at cybertec.com.au
