GCC modification for ARM
Charles Steaderman charlies at poliac.com
Fri Feb 21 23:50:59 UTC 2003
I am trying to port RTEMS to an ARM7 CPU. Unfortunately, the chip
manufacturer has a bug in which data corruption can occur when using DMA
when a SWP instruction is executed. I know that RTEMS uses patched
compilers and libraries and I was wondering if anyone is familiar enough
with GCC to direct me where to make a change to replace the SWP
instruction with LDR and STR instructions.
Thanks,
- Charlie
Charlie Steaderman
VP Engineering
Poliac Research Corporation
Phone: 952.707.6245
Cel: 612.242.6364
