GCC modification for ARM
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Feb 22 00:52:33 UTC 2003
Charles Steaderman wrote:
> I am trying to port RTEMS to an ARM7 CPU. Unfortunately, the chip
> manufacturer has a bug in which data corruption can occur when using DMA
> when a SWP instruction is executed. I know that RTEMS uses patched
> compilers and libraries and I was wondering if anyone is familiar enough
> with GCC to direct me where to make a change to replace the SWP
> instruction with LDR and STR instructions.
The source for this has to be in gcc-XXX/gcc/config/arm and is probably
in
arm.md. grep there and you might already find an option to switch the
behavior.
> Thanks,
> - Charlie
> Charlie Steaderman
> charlies at poliac.com
> VP Engineering
> Poliac Research Corporation
> Phone: 952.707.6245
> Cel: 612.242.6364
joel at OARcorp.com On-Line Applications Research
