gcc 3.2.2
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Feb 26 03:51:51 UTC 2003
Am Mit, 2003-02-26 um 01.18 schrieb Joel Sherrill:
> Brett Swimley wrote:
> But Ralf did mention some build problem
I had and still am having problems in building gcc-3.2.2 for the
linux->solaris cross-toolchain.
[Joel reported not to have this problems ;)]
>  and I don't recall the resolution.
Well, meanwhile I can reduce the linux->solaris5.7 problem to one single
problem, but have not found a work-around to this particular problem,
yet.
Anyway, this should not have any impact on linux->rtems toolchains.
> Ralf do you have a patch to 3.2.2 or is it time to turn the crank?
Well, I have your *try0.diff, had tried it once or twice for random
target-cpus, but have not systematically built rpms with it.
I also have a patch to arm-rtems-gcc pending, but this still requires
several iterations of building before it can be merged.
> > What's the chance of turning a toolkit with 3.2.2?  Anything I should know if I
> > wanted to take a stab at it (newlib & binutils versions and patches, etc.) or is
> > this in the works and I should just be patient?
> I think you should just be patient.  If Ralf doesn't have a patch for
> whatever it was he ran into, they don't take long to crank out.
I'd say, go ahead with whatever you have - As my pending patch only
affects the arm, we could easily replace arm-rtems-gcc later.
Ralf
