Passing vector number (was Re: API modification request)
Leon Pollak leonp at plris.com
Tue Feb 4 15:56:22 UTC 2003
On Tuesday 04 February 2003 13:49, Sergei Organov wrote:
> Eric Valette <eric.valette at free.fr> writes:
> > Besides, looking at the code when I changed the irq API, nobody was
> > actually using this vector...
> Please keep in mind that unfortunately you don't see all the code. There
> could be proprietary code that relies on features you change...
Ooops, here is the case...:-))
Our code uses vector number to determine the SCCx number caused the interrupt
in our MPC860 based system (there is one ISR for all SCC's).
But there may be a casting used to solve the issue, no?
leonp at plris dot com
