ISR Argument Proposal Request
Jerry Needell jerry.needell at unh.edu
Tue Feb 4 16:42:46 UTC 2003
Joel Sherrill wrote:
> Till,
> I think that we are all as much in agreement over this as we
> will ever be.  Let's see if I can summarize and request that
> you write up the API changes with a list of "key" area to
> change.
> Some issues that must be resolved:
>  + should rtems_interrupt_catch be backward compatable and
>    this functionality have a new entry point?  I lean to yes.
>  + should this feature be optional and conditionally compiled?
Joel - Could you be more specific as to the changes to the API that are
being proposed. I am frantically trying to evaluate the impact on the
SPARC bsp but this discussion is moving very quickly. Exactly where in
the API (bsp independent) would the proposed changes be implemented. As
it is currently implemented, we do get the interrupt vector passed to
the  ISR handler.
> The development plan needs to have volunteers for each of
> the following:
>   + generic change from table of handlers to table of
>     handlers/arguments
>   + each port's irq handling
>   + API changes to original interrupt API, ppc, x86, and ARM
don't forget about the poor old SPARC!
>   + documentation changes
>   + any work break down I am missing?
>   NOTE: When you change a port, I would consider that to include
>   getting all the BSPs modified.  Everything should still build.
>   I regularly build all BSPs so this is somethign I can provide
>   feedback on.
> We can't start this until we are confident all
> the ports will get updated.
-- Jerry
_______________________________________________________________________
Jerry Needell                     | Internet: jerry.needell at unh.edu
Space Science Center/Morse Hall   | Voice: (603) 862 2732
University Of New Hampshire       | FAX:   (603) 862 0311
Durham, NH 03824                  |
