rtems initilization, makefile & maling list archives !
gregory.menke at gsfc.nasa.gov
Sun Feb 9 15:37:30 UTC 2003
Salman writes:
> Hello everybody,
> 3 questions:
> 1. can all pci card (i386/pc386) initialization processes (initial
> setup/memory allocations and hardware configurations) take place at
> rtems_executive_early stage (similar to console & clock
> initializations)?
As long as its done after the bsp has done its thing configuring the
PCI hardware itself. It will be lots easier to manage if you don't,
however.
> 2. each time I change makefiles or code, I need to run
> bootstrap, configure and make
> would the configure and make be smart enough to just compile the
> modified sections, or do they compile the whole rtems?
> is there faster way? short-cut like?
You don't have to re-run bootstrap unless you're adding/removing files
from rtems itself or grovelling around in the system makefiles. Even
then, you only have to run it once to get propagate the new/removed
file. With few exceptions, a top-level make install will recompile
the modified code and install the new version of rtems in the output
directory.
Gregm
