Timer resolution
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 21 13:44:32 UTC 2003
Nigel Spon wrote:
> Hi,
> If I might intrude for a moment with a simple user question; does
> anyone know where or how I might discover the timer tick interval
> limits for using the RTEMS network stack: i.e how often should
> rtems_clock_tick() be called? I ask because it must have a bearing on
> how well the TCP retransmit timers, etc will work, and I suspect there
> is a minimum resolution requirement for 10Mbit and 100Mbit Ethernet...
The tftp and ttcp demos use 10,000 microseconds as their value. Given
that the source code is from FreeBSD, I would suspect that it doesn't
require a clock tick lower than that. UNIX was never known for having
low clock tick quantums.
My guess would be that anything 10 milliseconds or less would be fine.
But I would love to hear from someone else.
> Thanks for any assistance,
> Nigel
> "The Galaxy's a fun place. You'll need to have this fish in your ear."
joel at OARcorp.com On-Line Applications Research
