Error building RTEMS - Possible tools config error
Angelo Fraietta angelo_f at bigpond.com
Wed Feb 26 04:41:30 UTC 2003
I spoke too soon. That link did not work. I ended up with an error
i386-rtems-g++: "-c" is not a valid option. So I have a problem in the
way I configured the tools to start with.
Angelo Fraietta wrote:
> I had an error attempting to build RTEMS. I did the following (from
> Eric' page)
>   1.
>       ../rtems-ss-20030128/configure --target=i386-rtems
>       --prefix=/opt/rtems \
>          --enable-cxx --enable-rdbg --disable-tests --enable-networking \
>          --enable-posix --enable-itron
>       <snip>
>    2. Build and install RTEMS for one or more board-support packages
>       using the target architecture configured in the previous step.
>       The pc386 board support package which works on standard PC
>       hardware would be specified as:
>make RTEMS_BSP=pc386
> however I got an error that
>     i386-rtems-g++
> was not present. I looked in /opt/rtems/bin and it was not there so I
> made a soft link from i386-rtems-cpp to i386-rtems-g++, i.e.
>     ln -s i386-rtems-cpp i386-rtems-g++
> The build seems to be taking place just fine now.
No - it did not finish (after about 1/2 hour of building)
> Is it possible that there is a problem in building of the RTEMS
> toolset or have I done something wrong?
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
>http://www.users.bigpond.com/angelo_f/
>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>There are those who seek knowledge to be known by others - that is VANITY
>There are those who seek knowledge in order to serve - that is LOVE
>    Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20030226/9a4cbad1/attachment-0001.html>
