Web Server Demo Program
Mike Siers
mikes at poliac.com
Wed Feb 26 17:21:47 UTC 2003
Hi,
I think my real problem is in the untarring of the IMFS image.
I stepped through the function Untar_FromMemory(). This function
takes an unsigned char pointer and a size value. It does an offset
into the buffer and a string length compare with the string "ustar "
and a length of 7. This string compare is failing. The string that
I have in my buffer is just "ustar" instead of "ustar ".
I am building using an OpenBSD system instead of the traditional
Linux system. Could this be my problem? Or is this a bug in
the untar function? I will try hacking the function to see if it
fixes my problem.
Also, when I build the application, the call to i386-rtems-objcopy
to create the tarfile.o object file gives a warning that the output
file cannot represent architecture UNKNOWN. Is this warning normal?
Thanks
Mike Siers
-----Original Message-----
Sent: Wednesday, February 26, 2003 9:52 AM
To: RTEMS Users
Subject: Web Server Demo Program
Hi,
I am trying to get the http demo up and running. I am
using RTEMS snapshot 20021118 and network demos 20021018.
The http task (rtems_httpd_daemon) first calls to get the
host name (gethostname) and then calls to get the host
address (gethostbyname). The gethostbyname() function
is failing. I have added an entry into the rootfs/etc/hosts
file for my host name but when gethostbyname() does an
fopen() on the host file, the fopen call fails. I have my
CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS set to 20.
Any thoughts or hints on how I can get the http demo to
work would be greatly appreciated.
Thanks
Mike Siers
