code size latest snapshop versus 200206
till strauman at slac.stanford.edu
Thu Feb 27 16:20:07 UTC 2003
Joel Sherrill wrote:
>Chris Johns wrote:
>>Till Straumann wrote:
>>>It's not clear who is really responsible for the net increase
>>>as some things got bigger and some new symbols appear but other
>>>symbols shrunk or disappeared.
>>>There is also noticable fluctuation among small items.
>>I agree. Most items are small excluding the _vfiprintf_r/_vfprintf_r etc. Some call
>>must have been added to bring these in.
>>Not sure why the change has happened.
>If the references to _vfiprintf_r/_vfprintf_r are new, then
>please use the -Map option to ld to find out what is rerfercing it
>and forcing it in.
Hmm - I didn't look at the -Map yet but my guess is that hello world
calls printf who probably
wraps _vfprintf_r, the latter referencing _vfiprintf_r
---Till.
>I am in the middle of building tools so am not in a good position to
>check other targets.  What BSP are you using Peter?  If not a PPC one,
>then it is likely some shared support code and we need to find it and
>reduce the dependencies.
>>  Chris Johns, cjohns at cybertec.com.au
