code size latest snapshop versus 200206
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 27 14:37:50 UTC 2003
Chris Johns wrote:
> Till Straumann wrote:
> > It's not clear who is really responsible for the net increase
> > as some things got bigger and some new symbols appear but other
> > symbols shrunk or disappeared.
> > There is also noticable fluctuation among small items.
> I agree. Most items are small excluding the _vfiprintf_r/_vfprintf_r etc. Some call
> must have been added to bring these in.
> Not sure why the change has happened.
If the references to _vfiprintf_r/_vfprintf_r are new, then
please use the -Map option to ld to find out what is rerfercing it
and forcing it in.
I am in the middle of building tools so am not in a good position to
check other targets. What BSP are you using Peter? If not a PPC one,
then it is likely some shared support code and we need to find it and
reduce the dependencies.
> Chris Johns, cjohns at cybertec.com.au
joel at OARcorp.com On-Line Applications Research
