more multiple dec21140 on ppc
gregory.menke at gsfc.nasa.gov
Thu Feb 27 22:02:26 UTC 2003
Till Straumann writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > (sorry Till, I sent a copy to to alone by accident...)
> > I'm still working on it and have little more to report except that its
> > increasingly looking like something isn't quite configured right in
> > MPIC or the PBC.
> > Shifting the onboard dec to MPIC irq 2 (which its supposed to be wired
> > to) causes it to stop receiving interrupts (and I am changing its
> > INTERRUPT_LINE value to 2, with name = 18). I've only been able to
> > make the onboard dec operate under its ISA irq 10.
> Hmm - I cannot reproduce your problem on my mvme2306 board.
> Here's what works (with both, the original dec21140.c and the
> modified version you sent me a couple of days ago) on my board:
Figures- it sounds like your board is working the way its supposed to.
I am seeing some signs of life when I share ISA irq 10 between the
onboard and cpci dec boards, then poll them at int time to find out
which one is asserting. I am seeing some activity receiving ethernet
broadcasts on the cpci board (via if_tap), but no operation. I
suspect the board is not being configured right. I'm tracing the
board setup now.
> a) I do nothing, boot -> dec driver reports it is using interrupt 10
> which in fact is the ISA interrupt.
I get this from ppcbug as well. I'll give the csaw options a try, but
I'm not hopeful....
Thanks,
Gregm
