more multiple dec21140 on ppc <fixed>
Valette Eric
eric.valette at free.fr
Fri Feb 28 21:41:13 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> > One was booting and the other just loop asserting the interrupt always
> > looking the bott while the same binary was working fine on the other
> > board...
> I've seen some IDE strangeness on mcp750's as well. In our case, we
> cannot boot with the root filesystem on an IDE on any of our 4 750
> units running 2.4.19. Though once booted, all of them use the IDE
> just fine. We have to either use a scsi or nfs root. The nfs case is
> accidentally beneficial for driver developers because when the machine
> locks, theres no filesystem check on restart- which is nice.
I had patches to make MCP750 work correctly on IDE. I can try to find
them back on tape archive. But be sure that you specify the right root
when booting something like root=/dev/hdc1 because by default it use
SCSI. Also you must have a small primary prep bootable partition and
just dd vmlinuz on this partition. You can then boot directly from disk
using something like pboot a;
-- eric
