more multiple dec21140 on ppc <fixed>
gregory.menke at gsfc.nasa.gov
Fri Feb 28 22:45:01 UTC 2003
Valette Eric writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > > One was booting and the other just loop asserting the interrupt always
> > > looking the bott while the same binary was working fine on the other
> > > board...
> > I've seen some IDE strangeness on mcp750's as well. In our case, we
> > cannot boot with the root filesystem on an IDE on any of our 4 750
> > units running 2.4.19. Though once booted, all of them use the IDE
> > just fine. We have to either use a scsi or nfs root. The nfs case is
> > accidentally beneficial for driver developers because when the machine
> > locks, theres no filesystem check on restart- which is nice.
> I had patches to make MCP750 work correctly on IDE. I can try to find
> them back on tape archive. But be sure that you specify the right root
> when booting something like root=/dev/hdc1 because by default it use
> SCSI. Also you must have a small primary prep bootable partition and
> just dd vmlinuz on this partition. You can then boot directly from disk
> using something like pboot a;
We got lost hdc interrupts when Linux was probing the IDE hardware,
and it wouldn't mount root off the drive. Thats what made me think of
this edge/level setting possibility.
Gregm
