Newbie still having compile problems.
    James Fitzsimons
    jamesfit at paradise.net.nz
    Sun Jan  5 09:17:09 UTC 2003
Hi all,
I originally posted this just prior to Christmas, probably not a good time
to ask for help when everyone is so busy having holidays ;-) Anyway I am
still not going so...
I managed to persuade the newer versions of binutils, gcc and newlib to
compile on my machine ok, however when it came to building RTEMS I am still
having a problem.
I verifed the operation of the cross toolset as in section 5.4 of the
"getting started with RTEMS for c/c++ users" doc. The function f.c compiled
ok and I didn't seem to have any problems building gcc so I can only assume
the compiler is working correctly.
However I am getting an error in the configure phase of the build process
for RTEMS. I am configuring with the following switches:
bash-2.05a$ ../rtems-ss-20021118/configure --target=m68k-rtems
--disable-networking --disable-itron --enable-rtemsbsp=mrm332
--prefix=/Users/james/robotdev/RTEMS/install
The error is pasted below.
Any advice would be much appreciated.
Regards,
James Fitzsimons.
checking for awk... awk
checking whether make sets ${MAKE}... yes
checking for m68k-rtems-strip... m68k-rtems-strip
checking whether to enable maintainer-specific portions of Makefiles... no
checking if cpu m68k is supported... yes
checking for style of include used by make... GNU
checking for m68k-rtems-gcc... m68k-rtems-gcc
checking for m68k-rtems-gcc... (cached) m68k-rtems-gcc
checking for C compiler default output... configure: error: C compiler
cannot create executables
configure: error: /bin/sh '../../../../rtems-ss-20021118/c/make/configure'
failed for c/make
sed: confdefs.h: No such file or directory
bash-2.05a$
