Timers problem
Ilian Donev
idonev at flairbase.com
Wed Jan 8 20:44:02 UTC 2003
Hello all,
I'm new to RTEMS world and was (finally) able to build my first RTEMS
(4.5.0) with success on a PC running Mandrake Linux.
I installed the latest precompiled tools for Linux from the "cd-working"
directory and configured RTEMS for an i386 target, with bsp pc586 for
testing purposes on a PC.
All the demos compiled just fine. I picked the standard "Hello world" app
and booted from a floppy using GRUB. Everything was just perfect. I tried
several other apps from the sample directory
( tasks, semaphores, etc ) and was pleased with the results. So far, so
good.
Then the problem: each time I try to run an app which uses the
"Timer_Initialize " function I get the error "raw handler connection
failed".
I recompiled RTEMS for bsp pc386, tried it again on several PCs - same
error.
What could be the problem ?
Thank you in advance !
Ian
URL: <http://lists.rtems.org/pipermail/users/attachments/20030108/6e9b2040/attachment.html>
