RTEMS SS-20030128 available
Tue Jan 28 21:58:42 UTC 2003
Angelo Fraietta wrote:
> I have had a look at the tool versions and it has
> i386-rtems-gcc-gcc3.2newlib1.10.0-5
>  however, the working CD has
> gcc3.2.1newlib1.11.0-1
> Which is the correct one to test?
Both should work fine.  But that is an installation problem in
cd-working.
The snapshot was tested with gcc3.2.1newlib1.11.0-1.
Fixed now.  Thanks for the eagle eye. :)
> Joel Sherrill wrote:
> > A new RTEMS snapshot is available.  I hope this is the last snapshot
> > before a release branch is forked.  It is available in
> > ftp://ftp.oarcorp.com:/pub/rtems/cd-working
> > ftp://ftp.oarcorp.com:/pub/rtems/snapshots/rtems/current
> > A number of nits fixed, loopback network test added to samples,
> > and BSD sysctl() interface supported for the TCP/IP stack.  This
> > allows the standard SNMP package to work with RTEMS.  The BSP Howto
> > has been updated to reflect use of automake and the Getting Started
> > has the versions updated.
> > A few of the Ada binding tests link and run now but the Makefiles
> > need some magic before they all will.
> > Feedback greatly appreciated.  I am mentally setting a timer and
> > if there are no bad reports, when it goes off t
> > he release branch
> > is forked.
> > FWIW I am not merging the API change to rtems_io_register_name.
> > It will be a post release item.
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
