GDB 5.2 Configure parameters
Michael J. Siers mikes at poliac.com
Fri Jan 10 20:25:23 UTC 2003
Hi,
I am trying to build gdb 5.2 for the i386 with the rdbg support.  I have
applied
the three different patches:
   gdb-5.2-rtems-base-20020612.diff,
   gdb-5.2-rtems-cg-20020612.diff
   gdb-5.2-rtems-rdbg-20020612.diff.
I built gdb using the following configure command but I get an undefined
command
when I type "setrpcmode sun" using the i386-rtems-gdb binary.
  ../gdb-5.2/configure --prefix=/opt/rtems --target=i386-rtems --norecursion
Do I need to enable rdbg on the configure line?  What configure options
should be
used to build this?
Thanks
Mike Siers
