MVME 2400/2301/162/167 BSPs
gregory.menke at gsfc.nasa.gov
Tue Jan 14 19:52:54 UTC 2003
Joel Sherrill writes:
> Thomas Doerfler wrote:
> > Hi,
> > > Hello,
> > > I am new to RTEMS. I have downloaded ver 4.5.
> > > I also downloaded the bare BSP.
> > > I was hoping to find a BSP for MVME 2400/2301/162/167
> > > BSPs. Preferably, MVME2400 and/or MVME162.
> > There is sort of a universal motrola powerpc
> > board BSP located at
> > c/src/lib/libbsp/powerpc/motorola_powerpc/
> > with some readme files. Maybe this is a starting
> > point for you...
> More than maybe. :) The motorola_powerpc BSP has "aliases"
> to support a wide variety of Motorola VMEbus, CompactPCI,
> and PowerPC motherboards. The current aliases which are
> known are mvme2307, mcp750, and mtx603e.
> The mvme2307 BSP alias has been reported to work on most
> the mvme230x series so I would suspect it will just work
> on the mvme240x. Hopefully someone on the list can confirm this.
> I recall Greg Menke reporting the the mtx603e BSP variant would
> actually work on his mcp750 as well.
The motorola_powerpc shared bsp is fairly general. The
board/processor specific stuff is handled by #ifdef's. If the chipset
on the board is more or less supported by the existing code, a
nominally functional bsp should be easy to implement. If not, it will
require adding definitions and code to support the alternate hardware.
Gregm
