MVME 2400/2301/162/167 BSPs
Till Straumann
strauman at SLAC.Stanford.EDU
Tue Jan 14 20:09:55 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> Joel Sherrill writes:
> > Thomas Doerfler wrote:
> > > Hi,
> > > > Hello,
> > > > I am new to RTEMS. I have downloaded ver 4.5.
> > > > I also downloaded the bare BSP.
> > > > I was hoping to find a BSP for MVME 2400/2301/162/167
> > > > BSPs. Preferably, MVME2400 and/or MVME162.
> > > There is sort of a universal motrola powerpc
> > > board BSP located at
> > > c/src/lib/libbsp/powerpc/motorola_powerpc/
> > > with some readme files. Maybe this is a starting
> > > point for you...
> > More than maybe. :) The motorola_powerpc BSP has "aliases"
> > to support a wide variety of Motorola VMEbus, CompactPCI,
> > and PowerPC motherboards. The current aliases which are
> > known are mvme2307, mcp750, and mtx603e.
> > The mvme2307 BSP alias has been reported to work on most
> > the mvme230x series so I would suspect it will just work
> > on the mvme240x. Hopefully someone on the list can confirm this.
> > I recall Greg Menke reporting the the mtx603e BSP variant would
> > actually work on his mcp750 as well.
> The motorola_powerpc shared bsp is fairly general. The
> board/processor specific stuff is handled by #ifdef's. If the chipset
> on the board is more or less supported by the existing code, a
> nominally functional bsp should be easy to implement. If not, it will
> require adding definitions and code to support the alternate hardware.
AFAIK, the BSP expects to find a 'RAVEN' PCI hostbridge.
I found it quite easy to 'derive' a BSP for Synergy Microsystems'
VGM board series (MPC106 hostbridge, no ISA bus [memory mapped UART],
UniverseII VME bridge, Symbios 'yellowfin' ethernet interface) from the
motorola_powerpc BSP).
To simplify the task of 'deriving' a 'similar' BSP from
'motorola_powerpc', I separated generic code (such as the PCI
configuration space access routines) from more specific parts (e.g.
hostbridge detection) into separate files. The respective
modifications I did to 'motorola_powerpc' are present in recent snapshots.
The SVGM BSP overrides the respective files from motorola_powerpc
with its own versions:
/* basic definitions; memory layout, device addresses etc. */
include/bsp.h
/* interrupt routing */
irq/irq.h
/* VME / PCI address configuration */
vme/VMEConfig.h
/* irq controller setup/init; modified copy of the 'shared' version */
irq/irq_init.c
/* host bridge detection; replaces detect_raven_bridge.c */
pci/detect_grackle_bridge.c
/* board setup/init; modified copy of the 'shared' version */
startup/bspstart.c
/* ethernet chip driver */
svgm/network/yellowfin.c
If you have more specific questions, don't hesitate to ask
-- Till
PS: I still need to contribute VME and pagetable support
(i.e. generic 'setup' routines; the drivers are already
there) as well as the SVGM BSP itself...
> Gregm
