i386 GDB Thread Commands
Mike Siers
mikes at poliac.com
Wed Jan 15 18:58:30 UTC 2003
Hi,
I am using the i386/pc386 BSP for doing some initial testing
with the current snapshot. I built gdb 5.2 and can successfully
do debugging over a serial line. My question is are there any
commands in this build of gdb which will print out the RTEMS threads?
The rdbg version of gdb has commands like "info threads" but this
does not work with serial debugging.
Thanks
Mike Siers
