TECLA configure questions
Thu Jan 23 19:10:57 UTC 2003
Ralf Corsepius wrote:
> On Thu, 2003-01-23 at 15:49, Eric Norum wrote:
> > "M.C.Shao" wrote:
> > > From: Ralf Corsepius <corsepiu at faw.uni-ulm.de>
> > > > I don't know libtecla, so I can't comment on it, but basically, there
> > > > exist several principles to configure a package for cross compilation,
> > > > example
> > The bit script in the add-on packages directory should take care of
> > this.  Most of the add-ons are all configured and built the same way.
> > For each package there's a makefile fragment in RTMES_Makefiles.  Here's
> > how I just built the libtecla package:
> > cd src/RTEMS/rtems-addon-packages-20030120/libtecla-1.4.1
> > export RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/pc386
> > make -f ../RTEMS_Makefiles/Makefile.libtecla
> > Note that you must set the RTEMS_MAKEFILE_PATH environment variable to
> > reflect the architecture for which you're building.
> Ok, then I's suspect either the reporters configuration to be buggy or
> RTEMS application Makefile-stuff not to harmonize with libtecla
> expectations.
> I would have looked into libtecla, but ...
> ... once again, OAR's ftp is currently is close to being unreachable ...
We had an ice/snow storm overnight here and I am at home along with my
kids.
I suspect that most of Huntsville plus north Alabama and southern
Tennessee
is working from home today.  I noticed earlier today that it seemed slow
for my ssh connection to there.
> Ralf
