TECLA configure questions
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Jan 23 17:02:03 UTC 2003
On Thu, 2003-01-23 at 15:49, Eric Norum wrote:
> "M.C.Shao" wrote:
> > From: Ralf Corsepius <corsepiu at faw.uni-ulm.de>
> > > I don't know libtecla, so I can't comment on it, but basically, there
> > > exist several principles to configure a package for cross compilation,
> > > example
> The bit script in the add-on packages directory should take care of
> this.  Most of the add-ons are all configured and built the same way.
> For each package there's a makefile fragment in RTMES_Makefiles.  Here's
> how I just built the libtecla package:
> cd src/RTEMS/rtems-addon-packages-20030120/libtecla-1.4.1
> export RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/pc386
> make -f ../RTEMS_Makefiles/Makefile.libtecla
> Note that you must set the RTEMS_MAKEFILE_PATH environment variable to
> reflect the architecture for which you're building.
Ok, then I's suspect either the reporters configuration to be buggy or
RTEMS application Makefile-stuff not to harmonize with libtecla
expectations.
I would have looked into libtecla, but ...
... once again, OAR's ftp is currently is close to being unreachable ...
Ralf
