FQC API change was Re: RTEMS SS-20030128 available
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Tue Jan 28 22:33:22 UTC 2003
Steven Johnson wrote:
> Joel,
> > FWIW I am not merging the API change to rtems_io_register_name.
> > It will be a post release item.
> I assume you meant the API change to rtems_io_lookup_name I submitted?
Yes.  Could you please file it as a PR with gnats?  It makes things
easier to track.  My inbox is not as effective as it used to be. :(
http://www.oarcorp.com/cgi-bin/gnatsweb.pl
Login as guest/guest
> Since this re-entrancy / race condition problem isn't going to be fixed
> in the next release, is there another way to do this, that is safe?
> If you don't mind me asking, what's the rationale in not changing it?
I hated to make an API change this close to a release.  I have changed
the subject and if no one complains, I will merge it.  My conservative
nature was coming through. :)
> Steven
