RTEMS SS-20030128 available
Jack Cawkwell J.Cawkwell at open.ac.uk
Wed Jan 29 08:14:26 UTC 2003
Hi Joel,
I downloaded the previous cd image a couple of weeks ago. The download
worked
well, and took a number of hours using wget, but was very much easier with
everything
in one place. Also very easy to burn a CD without missing stuff.
However, the old bundle did not build, I am getting the same syntax errors
in header
files that is due to mismatched versions. If others have built from this
new
CD image, I will download that and try to build it, and abandon the old CD
image.
Jack
joel.sherrill at OARcorp.com writes:
>A new RTEMS snapshot is available.  I hope this is the last snapshot
>before a release branch is forked.  It is available in
>ftp://ftp.oarcorp.com:/pub/rtems/cd-working
>ftp://ftp.oarcorp.com:/pub/rtems/snapshots/rtems/current
>A number of nits fixed, loopback network test added to samples,
>and BSD sysctl() interface supported for the TCP/IP stack.  This
>allows the standard SNMP package to work with RTEMS.  The BSP Howto
>has been updated to reflect use of automake and the Getting Started
>has the versions updated.
>A few of the Ada binding tests link and run now but the Makefiles
>need some magic before they all will.
>Feedback greatly appreciated.  I am mentally setting a timer and
>if there are no bad reports, when it goes off the release branch
>is forked.
>FWIW I am not merging the API change to rtems_io_register_name.
>It will be a post release item.
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel at OARcorp.com                 On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>Support Available                (256) 722-9985
