about the driver of intel 82559 (not 82559ER) netcard under RTEMS.
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Fri Jul 4 14:58:21 UTC 2003
David liu writes:
 > Hello joel sherill,
 > Thanks for you.
 > I read the if_fxp.c file and It support 82559ER, not support 82559 netcard.
 > I modify the device id only , replace 0x1209 with 0x1229.  It can find the 82559 netcard,but it can't work.
 > Can you help me?
If you will find out the functional differences between the 82559 and
82559ER, I imagine we'll be able to help- or at least figure out much
work would be necessary.  If the 2 chipsets are similar it not take
all that much.
Gregm
