Gnat/RTEMS questions
Per Dalgas Jakobsen pdj at maridan.dk
Thu Jul 10 10:37:25 UTC 2003
Hi,
I'm in the process of setting up a development environment in Windows for Gnat/RTEMS to be used on an embedded i386 PC target.
I'm new to RTEMS and Ada, so please bare with me, if stupid questions are placed...
State:
I have installed RTEMS and GCC with Ada-support.
Current set-up:
*) rtems-ss-20030417
*) gcc-3.2.3
*) newlib-1.11.0
Compiled with pc386 BSP - meant to be running on a standard(?) Pentium PC.
Installed under Cygwin on a Windows 2000 box.
My target is connected to host through an ethernet connection and boots via Etherboot (located on a local harddisk) from a tftp server on the host. Etherboot is configured for tagged- and elf-images.
I have managed to compile and execute both the C and Ada hello-world examples. (ada-examples-20030129) - Very nice.
Questions:
What will be the simplest setup with the above constrains? Should I use i386-elf or just i386?
Any additional patches that can make life easier for the average developer?
Instead of this rather extensive makefile in the ada-example, I would like to be able to execute a "gnatmake <my_ada_file>" and get my executable. Is this possible at this point? I guess not - Ohh well, it's not that bad with the makefile.
Anyone have a better setup for developing Gnat/RTEMS applications?
Where to find Ada-source-code, general and RTEMS-specific?
I would like any comments, ideas and suggestions you guys might have on this.
Best regards
Per
IMPORTANT
The information contained in this e-mail is privileged and confidential information intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please immediately notify us by e-mail or telephone.
Thank you in advance.
